2000 deville computer says overheating but all seems fine...?
Hello
just bought a 2000 deville and fell in love. Two days later, wipers wouldn't turn off so replaced wiper motor. A week later one of the tv's in the back stopped working so when pulling wires from under front carpet, noticed water on driver and passanger sides....mechanic said ac evaporator or something was clogged and took care of it. Now the computer keeps saying check coolant levels. Had oil changed and coolant added....still says it. Now, computer shows engine hot and turns off ac and shows temperature on high. Open hood and car seems perfect to my husband....fan works, coolant area is fine...no leaks...and he says it's just the computer...but I'm freaking out. Overheats when driving not so much when just idle. Someone now said to reset computer by unhooking battery for a few minutes. Any suggestions ????
I just got this car a couple weeks ago and love it....but come on it's like a weekly issue now.
Thanks!!!
Thanks!!!
Being you just got it have CO test - coolant test done to eliminate head gasket concern. It is possible coolant temp sensor is degraded and it not reading correctly. You will need a scanner and thermometer to evaluate sensor.
mrwillc
42
02-23-2010 10:03 AM
