1999 deville ran out of gas shut down engine..will not restart - Cadillac Forum - Enthusiast forums for Cadillac Owners
Old 06-05-2010, 03:58 AM
Default 1999 deville ran out of gas shut down engine..will not restart
Hello all,
i own a 99 deville which runs perfectly fine for many many days. The car ran out of gas this morning,it was on empty when i drove it home last night. The car started this morning but then after driving it for a block it was out of gas and barely moved then I stopped the car. Went to put in 4-5 gallons of gas and it will crank perfectly but will not start.
Can any one tell me if there is a shut off or safety reset feature on the 1999 deville ?
Any advice on how to do this.
thank you in advanced
Old 06-05-2010, 10:56 AM
GM does not use "Fuel Pump Reset" switches. Check for codes and fuel pressure.
Old 06-05-2010, 07:12 PM
Default tank trash
That last bit of fuel may have had dirt, rust, goo, etc... check fuel filter .
Old 06-06-2010, 08:45 PM
Actually the fuel pump was burned out and when they took it out part of it was melted. Can a low in gas condition cause it to burn out and perhaps melt?
"Theft System Problem...Car May Not Restart" PCM/BCM Problem or Wires? JBeam4ME Cadillac Eldorado 19 11-14-2015 03:28 AM
96 deville 'theft system trouble car may not restart'? tommy36079 Cadillac Deville 8 06-29-2011 07:08 PM
car ran out of gas this morning after starting drove for a block then won't restart cadillacgeneration Cadillac Deville 0 06-05-2010 03:38 AM
95 seville ran out of gas, now won't start proplayer187 Cadillac Seville 2 03-30-2009 02:14 AM
cranks up and shut down johnny parks General Tech 1 09-01-2008 11:00 PM
Tags
05, 2000, 99, cadillac, cranks, deville, engine, fuel, gas, happen, pump, ran, run, runs, srx, start
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
