01-03-2010, 11:54 AM
1999 Cadillac Seville sts Coolant Leak - water pump crossover seal
I have a 1999 Seville sts with 80,000 miles on it. My car has been leaking coolant for a few weeks and the check coolant light finally came on today.
Wanted to know what could be the cause for the coolant leak? I just got the water pump and the pulley replaced 1 months ago. Also the car does not overheat so I'm hoping its not a gasket problem.
edited title
01-05-2010, 08:10 AM
Not sure but check the coolant crossover has a tendency to leak, this is what I was told by a dealership when inquiring about buying this car.
Good luck, hope it's not bad! My 06 Chev tk had a frost plug that was leaking, simply slight turn in with a 3/8" ratchet fixed that problem, wish all repairs were that easy! Maybe a shop can put a dye in the antifreeze to find the leak???? Not sure.
01-08-2010, 08:34 PM
if you have a leak ??
Is there coolant on the ground under your car ?
If so then pop the hood and look around for wet spots. Try to trace from the ground up as to where the leak is coming from.
BTW...there is no frost plug in a 99 Lac. Hope that rambling didnt confuse you or make you sound like an easy mark if you repeated it.
BTW... if its been only a few weeks since your pump was changed then you should maybe go back to the place that changed it ?!
Why did you have the pump changed in the first place ?
Did they flush the coolant out when they changed the pump ?
What was in there when it was changed...Green or Orange ?
Did they add the tabs ?
01-09-2010, 09:39 AM
if the cooling system has an external leak, there will be one or more of these:
1. fluids on ground or carpets
2. smell of coolant
3. trail stains on block, hose connections, or other engine components
- this is a visual ID
if the system has an internal leak, there will be one or more of these:
1. oil level will rise, with added coolant
2. white steam (not smoke) will be evident on tail pipe when engine is well warmed and running.
3. at load (climb a mountain), engine will overheat as exhaust gases (headgaskets) blow into the coolant system .. at normal driving, it may not show this
4. it will drive you nuts as nothing seems wrong except coolant keeps going low, probably headgaskets.
- this is a compression test time and exhaust gases in coolant test time
__________________
"If you're going through hell, keep going"
~ Winston Churchill
01-09-2010, 11:06 AM
There is coolant on the ground under the car, its not a big puddle though. The pump was replaced because my car overheated once and the water pump pulley belt melted 1 months ago. The car has not overheated since.
I also smell coolant almost whenever I start the car up. I am going to take my car back to the place that changed the water pump.
So could this actually be a headgasket problem?
Reason: want to add something
01-09-2010, 04:58 PM
possible, but unlikely ...
2. smell of coolant
__________________
~ Winston Churchill
01-09-2010, 09:12 PM
i had the same problem with my 96 seville have a mechanic check the hoses.
04-07-2010, 07:32 AM
it be nice to know what the final outcome was ...
__________________
Home of the Allante XYZ Facts & Allante FAQ
~ Stealth
04-07-2010, 06:55 PM
It could also be a slow leak because someone forgot to add the two manufacturer required cooling system seal tabs to the lower radiator hose when they changed the antifreeze. GM part number 3634621 or equal DEX-Cool compatible organic vegetable stop leak.
01-06-2011, 03:07 PM
I'm up to 98,000 miles now. I have a coolant leak from the water pump crossover seal. I was told this would be 800 to repair. Just spent 650 to have a cracked radiator repaired. Should I just try to sell this car or have it fixed?
Thanks for any info
Tags
06, 99, antifreeze, auto, cadillac, car, coolant, cross, cts, deville, leak, leaking, not, overheating, pipe  |
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
