1999 Cadillac Seville STS Blown Head Gasket, Need advice - Cadillac Forum - Enthusiast forums for Cadillac Owners
Old 01-09-2007, 08:08 PM
Default 1999 Cadillac Seville STS Blown Head Gasket, Need advice
Hello all,
I know what your going to say, "Blown head, Get a new motor", however I have purchased this car with 109,000 miles on it and can not afford to buy a new motor, yet I purchased the Thermagasket product from RX Auto of whom has guranteed that this product will work. This is the problem. I need to diagnose how the gasket blew in the first place prior to puting the product in. The heat does not come on and this car has not been touched by mechanic. Pleas help me figure out how the head blew so it does not happen again. Thanks
Old 01-09-2007, 11:18 PM
Default RE: 1999 Cadillac Seville STS Blown Head Gasket, Need advice
Old 01-10-2007, 02:31 AM
HELLO, first thing to do is check the radiator make sure it is clean in side if was pluged it could of caused the engine to over heat , this then causes one or both cylinder heads to warp from the overheating since they are aluminuim you will need to find out which side it is and remove head and have it checked for strightness and repair it then is stall anew head gasket you may have to use new headbolts,the overheating may have happend before you bought the car it is hard to tell hope this helps Chuck .
Old 02-23-2007, 02:32 AM
I have a 97 STS with the exact same problem as tomaxx, no local mechanic will touch the engine, the Cadillac dealership, says to get rid of the car andthat putting the bolts back in there's a 50/50 shot that it'll hold and keep it from running hot, so the work is not guaranteed, there's no way im getting rid of my baby i'm in it for the long haul. i'm thinking about gettin a new engine, so if anyone has done this or had this problem all comments would be appreciated, thanks in advance
Old 11-12-2007, 11:30 PM
Gm is sending a mechanic on wednesday to inspect my car to see if the heating core exploding was due to the faulty headgaskets, i really do beleive so due to everything i've read andall the stories i've heard of the 94-97 sts blowing the bolts, and also the fact that gm doesnt even make that engine anymore, i'll post again afterthe inspection and lety'all know what went down. If anyone has had any experience with this please post thanks.
Old 11-13-2007, 12:16 AM
Pulling treads is well do***ent, timeserts can fail also. I have replaced head gaskets without thread repair. Even the 00 and later have thread pulling, heat seems to be the main factor.I saw a someone selling an improved timesert on ebay consderably larger than GM timesert maybe worth looking to.I have no experence with them, but I willing to give them a try if occasion arises.
Old 11-13-2007, 09:16 PM
Exactly right, the heat was gettint through the thread or gasket whichever was leaking and the heat is so damn hot it bust out through what ever is weakest in the cooling system, when the heating core busted the first thing i felt was something burn my foot and then the vents started shooting out smoke, that was the firs time, the second time after the core was replaced the radiator busted due to the heat, hopefully gm replaces my engine, do you know what causes the threads to pull initially.
Old 11-25-2007, 02:50 AM
not worthit, get a used engine, that is what i had to do
need advise with GM Cadillac Northstar blown head gasket overmyhead Aluminum Block V8s 19 03-18-2014 09:56 PM
97 Deville blew head gasket & I need advice on price blueshound52 Private For Sale/Trade Classifieds 3 10-20-2009 07:24 PM
Northstar Engine pulled head bolts/blown head gasket/overheating VIN9 Aluminum Block V8s 2 09-19-2007 10:18 PM
Blown head gasket, HELP! lisekpl Cadillac Seville 3 02-21-2007 10:32 PM
blown head gasket Jackie OH General Tech 1 07-22-2005 10:43 PM
Tags
1999, 96, 97, blown, cadilaic, cadillac, gasket, head, headgasket, overheating, repair, seville, stop, sts, thermaseal
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
