Sponsored by:
Sponsored by:
1996 Seville water pump
Old 10-08-2007, 10:51 AM
mj982000's Avatar
Default 1996 Seville water pump
I have a 1996 Seville, I'm trying to re-place the water pump is there a certain way to re-install the pump? Every time I put it back together the fluid pours out the back of the housing. I've replaced the o-ring, cleaned it out. Is there a certain way the clips on the water pump have to be in order to securely fit in the housing? Any help would be greatly appreciated.
Old 10-08-2007, 06:32 PM
Default RE: 1996 Seville water pump
Are you using special tool to install pump?
Old 10-09-2007, 06:04 AM
mj982000's Avatar
Yes, I'm using the special tool. One of the retaining tabs are different from the rest. Is there a certain spot in the housing for that tab?
Thanks for your reply.
montrose2914
04-13-2012 05:32 AM
FilthyPhil
02-19-2012 11:39 AM
DJWerkz
04-17-2011 04:46 AM
edgrmndz
02-19-2011 07:06 PM
threnc
07-09-2007 02:09 PM
Quick Reply: 1996 Seville water pump
