1995 Cadillac deville won't start when engine is hot - Cadillac Forum - Enthusiast forums for Cadillac Owners
Old 08-29-2008, 11:14 PM
Default 1995 Cadillac deville won't start when engine is hot
Hi guys im new to this forum. I recently purchased a 1995 cadillac deville. The car will start when it has been sitting for a while, but when the engine is hot it will not start. The motor turns over very slow for a second and then nothing at all. I tried jumpstarting the car off of a friends truck and it just turned over real slow a couple times and then nothing at all. This makes me think that its not the battery. If you let it sit after this happens for a while then it will start up. I put new spark plugs in it and changed the oil the other day. The last time i went to start the car i turned the key andthe dash lights came on but it did not turn over (this was after it had been sittingall night too). Also the car seems to sputter a little bit sometimes but not real bad. Does anyone have any ideas what the problem could be? Thanks for the help.
-Matt
Old 08-29-2008, 11:22 PM
Default RE: 1995 Cadillac deville won't start when engine is hot
Quote:
ORIGINAL: mmayer
-Matt
i would put my money on one of two things:
- bad ground
- dying starter
I highlighted the key items that leads me to that conclusion
check the codes for more info and post them.
Old 08-29-2008, 11:31 PM
alright thanks. Do you happen to know where the ground is located? Also the starter... i think its in the front of the motor by the manifold but imnot positive. Correct me if i'm wrong.
Thanks
Old 09-01-2008, 10:52 PM
Quote:
ORIGINAL: mmayer
I was wondering where the starter is located on my 1995 deville 4.9L? I am away at school right now so i havent had a chance to look.
Thanks,
Matt
Quote:
ORIGINAL: stomper
take a few beers .. sit down, take a deep breath !
if you pull the intake manifold, after disconnecting all the tubes, hoses and wires, you will see the Grand Canyon .. and a beer can like object at the bottom of the canyon ..
that, my friends, be the starter.
Old 09-02-2008, 03:48 PM
Katzmans Caddy's Avatar
Is this a 4.9 or 4.6, makes one heck ofa difference.
Old 09-03-2008, 12:34 AM
Quote:
ORIGINAL: Katzmans Caddy
Katz,
good catch!
sure does .. I missed that bit of detail.
Engine Hot / Stop Engine Great White General Tech 0 01-08-2013 01:53 PM
89 Allante won't start when hot Dennisoates Cadillac Allante 1987 to 1992 Phase I & II 2 05-25-2012 11:13 AM
Engine Coolant Hot/Engine Hot/ messages Mags1 Cadillac Deville 6 11-19-2010 08:37 PM
2001 deville won't start, engine turns over telecros Cadillac Deville 12 08-29-2009 09:34 AM
How HOT is HOT for a northstar engine. When do you suspect blown head gaskets bighank General Tech 2 11-18-2007 08:50 PM
Tags
1993, 1995, 1999, 49, 57, cadillac, deville, engine, hot, key, slow, sputtering, start, suburban, turn, warm, wont
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
