Sponsored by:
Sponsored by:
just bought 81 coupe
Old 03-24-2010, 12:47 AM
blockbeeda's Avatar
Default just bought 81 coupe
hello first of all hello to everyone,i just bought a 1981 coupe,it still has the original 368 engine in it,but it looks terrible,i want to remove it and swap it with another engine but i want something simple to work on that fits right in please help.my friend has a chevy 350 in his but his motor mounts came loose because they were welded,i dont want or need those kinda problems,any advice will be well appreciated,thanx in advance.
Old 03-24-2010, 07:31 PM
There is a fair mount out about sbc swap, just search it. 368 could be simpler also, if car is DFI you will need to remove most of engine wiring and related sensors. If you do if carefully you could resell many of the DFI parts, and re-coup some of your costs over time. 4 barrel carb and intake along with non-DFI distributor should be fairly easy to find in salavage yard.
Old 03-25-2010, 03:53 AM
blockbeeda's Avatar
thanks slowroll,ive decided to go 350 chevy one belt it seems simpler alot of my wires are dry rotted so im pull that bad 368 and see whats going on,thanks again.
randymoe
09-04-2008 05:41 PM
Sams03CoupeDeville
11-13-2007 12:54 AM
BulgarianGuy
Eldorado Brougham
12-20-2006 02:49 PM
LCD
08-20-2006 08:05 PM
Wolfspring
07-19-2006 07:21 PM
Quick Reply: just bought 81 coupe
