1994 sts, wont start? starter?
Old 03-26-2010, 05:28 PM
Alpine's Avatar
Default 1994 sts, wont start? starter?
i turn key , just hear "click - click"
im new here , know nothing bout cadilacs at all
is there a guide on how to replace starter?
do i need a gasket set when i replace?
Old 03-26-2010, 06:51 PM
Starter is under intake. It would be good idea to have intake gaskets available and possible spacer(s). Gaskets are designed to be re-used, but it is a 16yr old car. Its not really a job for a novice alone. If your are care full you can take the 4 bolts that hold intake down out and using a block of wood to hold passenger side of intake up high enough to remove starter without completely disconnecting / removing intake.
Old 03-27-2010, 07:24 AM
woo woo..... are you sure you have a starter problem???? has your car when starting, turn slow at times?? have you tryed to jump?? have you checked battery???
usually when starter goes you will have some type of warning as stated above. when it gets real bad, sometimes it wont turn, and the next minute it will...
hope it helps... keep the forum posted please..... let us know wad-up
Old 03-27-2010, 01:09 PM
Alpine's Avatar
took battery to autozone got it tested
i jumped the car , which gets me thinking its not starter
maybe ignition?
sometimes when i turn the wheel i an get it to start
woke up this morning tried to start it , and it had a loss of power. no dashboard lights, couldnt even lock the doors
Old 03-27-2010, 01:53 PM
okay... what kind of climate do you live in, and where is the car from climate wise. you said you had battery checked, im thinking its okay, right? you maybe on the right path as far as ignition. has that ever been changed, that you know?
really, it seems that you have a draw on your battery some where.... have you check connections??? grounds -, and positives + ???? is there anything left on? check all and get back... miles on car please?? how long have you owned the car???
still could be starter though..... as i asked in last post, " have you ever felt the starter drag?" drag = crank slower than normal..
good luck dude.... keep us posted
Old 03-27-2010, 07:56 PM
Search "no start". Check condition of battery cables.
Old 03-27-2010, 11:32 PM
one more thing?
read our thread on e-ghosts, in the FAQ section i believe.
for all you know, its a connector issue and that thread will enlighten you on the what to do at next to zero cost.
Old 03-28-2010, 06:38 PM
tombomb661's Avatar
jump it and take it to autozone. they can check both your battery and alternator. if there is no corrosion on batter cables and posts and the alternator and battery are good, it would most likely be the starter
Jack West
11-12-2012 11:07 AM
todd_vette
01-18-2011 08:15 PM
wildstylegrafix
01-15-2011 10:51 PM
umoms
03-03-2008 02:04 PM
usry28
11-21-2007 06:14 PM
Quick Reply: 1994 sts, wont start? starter?
