Sponsored by:
Sponsored by:
1976 Cadillac Eldorado-Trunk Issue
Old 04-16-2017, 03:14 PM
Traderdon88's Avatar
Default 1976 Cadillac Eldorado-Trunk Issue
I have a 1976 Cadillac Eldorado Convertible. Been sitting for years. Anyways, The button in the glove box wont ooen the trunk, and I have no trunk key
ANyone know of a way to open the trunk?
Thanks
Old 04-16-2017, 06:39 PM
Trunk key should be the same as door key. If you have a door key, but it won't open trunk, you may have to drill out lock cylinder. A good 3/8 drill bit should work. Once through lock a 10 inch long flat blade screw driver should release lock. If you don't have a working door key. Take a door lock cylinder out and take it to locksmith and have a key made from the coding. It may open trunk, if you will need to drill cylinder. You could also try to jump 12v to/across switch and see if trunk will pop.
Old 04-16-2017, 07:53 PM
So Long's Avatar
Do you have the battery hooked up? If so, my next step would be to pull the glove box to make sure the two wires for the button are connected.
Old 04-18-2017, 02:00 PM
thank you
09-17-2014 12:19 AM
RacingJunk
05-02-2013 03:23 AM
20RPM
12-20-2009 07:49 AM
Sonny1976
Vintage & Classic Cadillacs
01-18-2009 04:13 PM
Quick Reply: 1976 Cadillac Eldorado-Trunk Issue
