Service ride control, How do I scan the code and fix this?
Old 02-12-2015, 07:41 PM
GHOSTOWLGRID's Avatar
Default Service ride control, How do I scan the code and fix this?
I want to fix this dumb service ride control message.
The OBD2 scanner I have can not scan for the code, it does not see any codes, how can I scan for the correct code?
Also, what would need fixed? I inspected all the level sensors and such, everything looks fine, the rear air pump works normally, I do not understand what could be causing the code.
Some assistance would be good as I do not know where to start.
98 devill
10-01-2009 07:50 PM
alec_b
01-13-2009 09:14 PM
Quick Reply: Service ride control, How do I scan the code and fix this?
