01-25-2008, 12:18 PM
Pull the GM Diagnostic OBD CODES .. how ?
__________________
Home of the Allante XYZ Facts & Allante FAQ
~ Stealth
06-21-2008, 11:10 AM
RE: Pull the GM Diagnostic OBD CODES .. how ?
how do i go about resetting my obd systems I had some old codes and trying to make sure the ones i have at the momment is new and needto know how to fix them . PO171 & PO174 both are too lean codes, PO300 ramdon misfire but it not, PO603 memory error,P1632 THEFT SYETEM FUEL, AND last is the TCC PO741stuck off
__________________
thank you
06-21-2008, 11:15 AM
forget to tell you the year is 1996 deville
__________________
thank you
06-21-2008, 12:50 PM
Disconnect the battery for a few minutes.
or try this
PRESS:
OFF & WARM (red button) together
- the D.I.C. will light up the instrument cluster like a Christmas tree
- the D.I.C. will start diagnostics, as soon as it starts displaying ..
PRESS:
LO
- until " ECM " comes up
PRESS:
HI
- until " CLEAR CODES ? " comes up
PRESS:
HI
- press only once
- response will be in a few seconds: CODES CLEARED
you are done ...
PRESS RESET and you are back to normal
__________________
occ
z06
93 allantesold
sts maybe in December
08-17-2009, 02:51 PM
Do older Cadillacs (1968's) have codes?
09-06-2009, 10:04 PM
hmmmmm
do you clear the codes on a 95 sls the same way?
09-07-2009, 01:18 AM
Quote:
no ...
Quote:
yes ...
__________________
~ Stealth
09-07-2009, 07:42 AM
sls
thank you.
09-07-2009, 10:12 PM
hmmmm
i tried to clear my codes i never found the ecm to clear it now what do i need to do?
thank you
09-08-2009, 09:00 PM
After all the codes are displayed, DIC should display "PCM". Press high blower button and you will be in the ECM/PCM module options. Press low for no and high for yes for what comes up. on 82-95 Cadillac powered models scanner is not required, diagnostics intended for use with "on-board diagnostics". 80-81 DFI or 8-6-4 are unique to themselves, still have "on board" but access and data are different. Cimmaron and 86-96 RWD Fleetwood or Brougham require scanners. EFI - no onboard, no scanner, nor codes "Symptom Charts"...FSM,DVOM, and a prayer or two.
Tags
2000, 96, cadillac, codes, cts, deville, dts, escalade, obd, odb, po174, po300, pull, resetting, transmission  |
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
