Pull the GM Diagnostic OBD CODES .. how ?
  #11
Old 09-08-2009, 10:04 PM
jons95sls's Avatar
thank you i thought so.
  #12
Old 09-08-2009, 10:09 PM
jons95sls's Avatar
but if i may be so bold to ask,these cars have more problems than any auto i have ran across,im an auto electrion by trade,an these cars have always puzzeled me,i wish they would make a scaner just for cadys like this,but i still lv my sls,its so cool to drive.i will overcome this car,i just think if i own it i should an will cure it.thanks for all yr help.
jon.
  #13
Old 09-09-2009, 09:56 PM
jons95sls's Avatar
i found something out about the cady codes today,the computer system in these cars are tied togather,now what i mean is if it puts out one code it will throw out many codes for many other thing that throws you off,and can be as little as couple of pin in the pcm plug.I will share more info as i get it.
  #14
Old 09-10-2009, 07:27 PM
In regards to the scanner; it is built in to the car, you just need to know how to use it.
  #15
Old 09-22-2009, 12:24 PM
RE2's Avatar
RE2
RE2 is offline
This STICKY would be great if it actually had a link to a list of the codes.
  #16
Old 04-05-2010, 10:09 PM
Originally Posted by stomper
slowroll, do you know if there a list of Cadillac/GM vehicles that are equiped with on board diagnostics and code ability?
i love the system on the Allante, but i'm sure that is not available on most cars.
Originally Posted by slowroll
On-Board = 80-81 DFI HT4100 and 6.0 including 8-6-4, limited - access is different you will need manual for sure.
82-85 - HT4100 Eldo, Seville, and DeVille / Fleetwood (RWD)- engine only
85-93 - Deville / Fleetwood (FWD) Engine / Body system codes
94-95 - Deville / Concours - enhanced On-Board - for multiple systems.
96-05 - DEVILLE / Concours / DTS / DHS - Codes access to some systems.
86-95 Eldo / Seville / Allante' enhanced On-Board - for multiple systems.
96-04 Eldo / Seville - Codes access to some systems.
93-95 Fleetwood - limited On-Board - Different than the DFI
NO- On-Board - Cimmaron, DTS,CTS, STS, Catera, EFI (80 and earlier port fuel injection), XLR, 86-92 RWD Brougham, and SUVs. On-board faded away as models updated after 1998 model year.
  #17
Old 04-05-2010, 10:22 PM
i guess you missed the links? from the opening post ...
Originally Posted by Stealth
When your Caddy has problems,
WE NEED THE CODES.
PLEASE PULL THE CODES !
GM uses OBD-1, OBD-II, OBD-III Codes
Ohh, you dont know how to do it?
Here are a couple of help threads:
this 1st one is very detailed ..
https://www.cadillacforum.com/m_11904/tm.htm
these have additional info and links
https://www.cadillacforum.com/m_12932/tm.htm
https://www.cadillacforum.com/m_15478/tm.htm
https://www.cadillacforum.com/m_17425/tm.htm
  #18
Old 05-28-2013, 05:09 PM
Zynder's Avatar
Necro'ing this dead thread because all of the links are broken yet it is still a "sticky"
Please update.
  #19
Old 07-02-2014, 04:14 PM
maxximillion's Avatar
Hi,
Sir, I just bought a 2007 Cadillac CTS on Saturday with 95,000 miles on it. Two days later, I had gotten a check engine light, so I went to get an OBD check.
I had received these codes: U1016, P0017, P008, C0047, C0052, C0781, and C0561. I also bought a Wynn's Deluxe Warranty when I bought this vehicle.
But, based on the codes, how much could I be looking at in repairs? Could I still be screwed even with this warranty and all? Your help and expertise in this matter would greatly be appreciated.
  #20
Old 11-17-2017, 07:16 PM
Drbrown's Avatar
Default Links dead
Links listed in earliest posting here are now dead - pages gone.
maxximillion
07-02-2014 08:10 PM
Skotty
10-29-2012 03:29 PM
joanscar
09-01-2012 09:46 AM
cady97dev
03-29-2009 08:17 PM
manchutiger
05-02-2008 10:16 AM
Quick Reply: Pull the GM Diagnostic OBD CODES .. how ?
