GM Cadillac engine overheats, pump, rad, headgasket, head bolts, misc others ...
#13
overheating and then cooling down a tad
have a 2002 Cadillac Seville SLS norhtstar. 174,000 miles original owner. recently overheating. radiator and cooling system flushed by a garage. Mentioned it was very very 'plugged' up with gunk. Later, the mechanic after putting it back together said: blown head gasket. Now: No white smoke from tail pipe. Engine runs smooth. No water in oil:clean. Engine heats up after 15min driving and then cools back down to 'just over heating zone, but not back to normal. upon checking: cap has sprayed fluid around the neck of the 'bottle'. Next day I notice it is low approximately 1-1/2 gallons....I fill with GM orange raditor fluid and water/50/50. Currently drove car and still overheats...but upon driving...returns back to one 1/4 over normal on the gage. Is this a thermostate problem? Also the fluid, yes orange in color is sort of a whipped orange foam at top of cap upon upon opening.
thanks
u4s
thanks
u4s
VIN9
Aluminum Block V8s
09-19-2007 09:18 PM
choust1
Aluminum Block V8s
05-07-2007 06:22 PM
