Eldorado temp problem
Old 06-25-2012, 10:15 AM
dsparry's Avatar
Default Eldorado temp problem
My 2002 Eldorado engine temp gauge seems to rise quickly when ilding or driving at adjusting speeds. Can anyone tell me more about this?
Old 11-19-2014, 09:55 AM
philwil1944's Avatar
I have a 2002 ETC with only 27K miles which I purchased new. The engine is overheating. I replaced the thermostat & rad cap. I also checked for blown head gasket with an Engine Block tester. No dioxide in water tank. Yesterday I found the cooling fans are not working unless I turn the A/C on. I'm trying to check the sensor switch but so far I have not found any website that tells me how to do that. You can check your fans to see if they come on when the engine is hot.
Bigdamo94
11-01-2014 03:06 AM
cam
08-05-2013 06:05 AM
g92392
06-12-2006 09:13 PM
BOBPRICE
12-05-2005 02:35 PM
topaz92
04-14-2005 02:36 PM
Quick Reply: Eldorado temp problem
