Cadillac DeVille on 22 inch wheels / rims
Authored by 7tcutty.........thanks for the info
here is an fyi if your going to put 22s on a deville you need a 22x8.5 rim and you can use a 255/30/22 tire. you will need to roll the rear fenders out of the way and it may rub on the inner feners in the front where there is a section that sticks out.. but thats it..
if u go any wider on the wheel with you will need to lift the car and it will look corny (in my opinion) the tires will be streatched on the rims also and that is not good for the tires, 9+ inches is too wide for that size tire. not to mention it will not have the LAC ride either..
you can fit 24s under these cars also but its realy realy not worth it. you will need a 8.5 rim and its way to skinny [align=right]
[/align]
[/align]
dddowntown
03-19-2011 01:11 PM
