Northstar misfire weird
#11
So
I checked fuel pressure and it was at 60psi. Haven't done it down road but I let it run for about 3 minutes. When I unhooked tester the Schrader valve stuck and it depressurized the line. It had a ton of air in it. I have no idea h own with a 3/4 tank of fuel this could happen
#12
Are you sure gauge reads psi and not kpa. 60 psi is too high. running should be around 36psi. When you turn key on pressure typically is 40-45 and will drop around 5-8 psi when engine starts. You could a have problem with fuel regulator or restriction in return line.
#13
I did discover some stuff today. The psI driveing is 60 and after driving a little it's 50psi and no lower. I found coil three bolt holding it down was 1 full turn loose and I don't see that being an issue that high rpm miss has gone away now. I do however still have miss at idle. It gives p0308 and p0300 and when backing out of driveway it have p0019 and when it have that it stumbled pretty hard. I left fuel pressure gauge on all day and when I got home 30min later I checked to see if it dropped and it went down to 15psi in that time frame. I suspect bad injectors sticking. I checked vacuum and have 15 inhg vac but the needle jumps a little to match the skip within a pound. I'm assuking just cause of the skip. I hooked to the vac line going to booster and when I rev it lightly the vac jumps to 20 and shakes the needle around 3psi either way. I really appreciate the help.
#14
#15
The regulator in this case would be with fuel pump. At this point I would either get a FSM disc from helm inc or subscribe to Alldata for service information. GM stopped using printed service manuals in 2000-01 depending on carline and went to online service manuals.
