History Codes
History Codes
Will any of these History codes keep the car from starting?
Thanks!
P0204 - Injector 4 Control Circuit
P0603 - Control Module Long Term Memory Reset
P1133 - Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 1 Sensor 1
U1096 - Loss of Communications with IPC
U1088 - Loss of Communications with SDM
U1064 - Loss of Communications with DIM
Thanks!
RE: History Codes
It turns over, andI depressed the shrader valve and there is fuel pressure.
The battery is new and I made sure is was fully charged. Turns over fine.
I can not get to it this weekend, but I will go thru and check all connections and pull the plugs.
If I find anything I'll post the results.
Thanks!
1997 Deville
Thanks!
1997 Deville
02-14-2011 11:58 AM
