View Poll Results: A poll
Engine with 100,000+
30.43%
Engine with 150,000+
43.48%
Engine with 200,000+
13.04%
Engine with 250,000+
8.70%
Engine with 300,000+
4.35%
Engine with 350,000+
0%
Engine with 400,000+
0%
Engine with 500,000+
0%
Engine with 600,000+
0%
Engine with 800,000+
0%
Voters: 23. You may not vote on this poll
Cadillac Engine Life
Old 08-25-2007, 12:40 AM
bnonit's Avatar
Default Cadillac Engine Life
What is the average engine life on a N* engine? This question is in general as I am still openly searching and haven't found any specific cadillac of interest. I'm not sure if this question has already been answered on this forum, but I have searched both here and on search engines, and haven't found an answer. Any feedback, if only opinions, would be appreciated.
Moderator Edit:
Added Poll
Old 08-25-2007, 07:43 AM
G.A.R.Y.'s Avatar
Default RE: Average Engine Life
I can't tell you what the average is, but the very first N*'s (1993 allante) are still drivin around, many of them with well over 100k.With, PROPER MAINTENENCE,these motors should reach 200k easy, IMHO.
Old 08-25-2007, 04:51 PM
ORIGINAL: bnonit
be appreciated.
we simply dont really know.
for the most part, the engines are outlasting the cars themselves.
a few fail prematurely, usually of no fault to the engine itself..
all the Cadillac and GM aluminum engines, including the N* are
a tiny bit sensitive to a combination of loss of coolant, overheat,
and depletion of oxidation protection from the coolant, and failed
headgaskets due to a combination of that.
other than that, they seem to go and go until the wheels fall off the car.
that includes all 4100, 4500, 4600 (early V8 N*) and the modern
NorthStars V6's & V8's.
IMO, any used N* engine car should be tested and certified for
headgaskets integrity, specially if you are paying $5,000 +++
check our FAQ section for the various tests ...
Old 09-14-2007, 10:37 PM
Katzmans Caddy's Avatar
I've seen 3800 V6's in salvage yard in cars with several hundreds on them, the most I've seenwas anOlds 98 with 409,000 km.. That's over 250,000 miles. I tend to agree with G.A.R.Y.
Old 09-21-2007, 01:48 AM
I'm getting close to the 312,000 mile mark. I know Chevy gives badges and such for vehicles with over 200,000 or so.. I wonder if Caddy does that also?
Old 09-21-2007, 06:34 AM
You should contact someone at Cadillac Conrad, you could be the Northstar Poster Boy!
Old 09-21-2007, 08:32 AM
ORIGINAL: Conrad
Ever open the engine?
what is the story on the tranny?
Old 09-21-2007, 11:54 AM
In May I did a tune-up and when I was changing the plugs/wires, the wire boots had a rust residue on every one. Is that a hint there was a head gasket problem?(3rd owner) The transmission is original. Had it in for filter/fluid change in June. Everything looked clean. However, I do have the infamous tcc stuck off once in a great while.
Old 09-21-2007, 03:39 PM
As far as I know aluminum does not rust. Rust is ferrous oxide and you would need some fe = iron content present to produce rust.
Old 09-21-2007, 03:53 PM
ORIGINAL: Katzmans Caddy
iron needs water and oxigen to rust, aluminum only needs oxygen to "oxidize"
there is a reason all alum wheels are coated ...
Quick Reply: Cadillac Engine Life
