2003 CTS throttle body position sensor
Anyone know how I go about replacing the TBPS? I believe it is the unit next to the intake? I was told by a mechanic after checking the codes that the TBPS was bad. Erratic idle, rough shifting in the transmission, drop in MPG,. Once hooked up, do I need to re-set it? Any help would be appreciated.
Thank you
Thank you
crosscomp
12-05-2005 07:23 PM
