1994 Cadillac Eldorado
Old 10-11-2009, 07:25 PM
David Cameron's Avatar
Default 1994 Cadillac Eldorado
My eldorado was overheating and I took it into the shop and was informed it needed a new water pump. I choose to repair this myself and save a little money. After replacing the water pump and thermostat the car is still overheating. I have checked for leaks and it appears there are none. What should I look for next?
Old 10-12-2009, 05:58 PM
Check for blown head gasket - have CO coolant test done.
Old 10-12-2009, 06:05 PM
Check for blown head gasket, have CO - coolant test done.
Old 06-27-2013, 02:03 PM
Tony Ruth's Avatar
Default 1994 Eldorado TC
I've got a couple of issues with this car. Purchased it last year and it ran perfectly up until about two months ago. Since then I've had to replace the alternator and the instrument cluster is acting up on me. It comes and goes, mostly goes anymore, it hardly ever comes on. This morning on the way to work the service engine soon light flashed on then went off. The car seemed to hesitate for a moment then went back to running normally. This happened for about the last five miles I drove this morning and since the instrument panel is not working I have no idea why it would do this. I check the oil and coolant every other day out of sheer paranoia but have noticed no significant drops in levels. PLEASE HELP! NOT SURE HOW TO FIX THE INSTRUMENT CLUSTER OR IF THAT IS EVEN THE PROBLEM. NO IDEA WHY THE SERVICE ENGINE LIGHT WOULD DO WHAT IT IS DOING, ANY ADVICE WOULD BE GREATLY APPRECIATED. Honestly I love this car and can't bare to see it die. Thanks for your time.
Old 07-22-2014, 02:15 AM
Bill Zhao's Avatar
thank you for your sharing
rbradney
07-24-2018 12:50 PM
RacingJunk
05-26-2014 03:20 AM
JoweeCadillac
05-21-2008 10:20 PM
tatjefe
12-26-2007 11:42 AM
badcadguy
03-30-2005 04:24 PM
Quick Reply: 1994 Cadillac Eldorado
