Why diesel engine car shows low speed at the time of starting than a petrol car?
1. A diesel engine is more easily turbocharged than a petrol engine. A petrol engine cannot be easily turbocharged due to the fact that if the compression ratio and the pressure in the cylinder is to high during the inlet stroke, the mixture starts to burn to soon, while the piston is on its way up. The diesel engine has no fuel in the cylinder, thus letting the turbocharger suck as much air as it can without creating any problems. (A turbo charger is a simple air compressor which compresses air in the combustion chamber for burning). Some diesel engines also have an intercooler which helps in blowing cold and oxygen rich air in the combustion chamber.
2. Petrol destroys lubrication and burns the engine whereas diesel doesnt. So a diesel engine would last longer than a petrol engine
3. Diesel engines have better fuel efficiency as compared to petrol due to the fact that they have higher compression ratio.
4. Diesel engines have higher torque than petrol engines. What does this mean? Well, this means that a diesel engine would pull heavy loads easily than a petrol engine. Though the pickup of a petrol engine would be much more than that of a diesel engine, the diesel engine would be steady and carry heavier loads to longer distances.
Extremespeedtrackevents
07-01-2014 01:16 AM
