Need Tech Help! NO HEAT!! 1998 Cadillac STS - Cadillac Forum - Enthusiast forums for Cadillac Owners
Old 01-04-2009, 11:40 AM
Default Need Tech Help! NO HEAT!! 1998 Cadillac STS
1998 sts 1998 sts, heat fan only goes on when it wants to?? Didnt work for a week froze my *** off, then ckd the coolant level, and noticed it was low, added about half a gal, and then just like that the heater kicked on????
worked that day, the next day diddnt then did, and now dosent!
Old 01-04-2009, 11:49 AM
Default RE: Need Tech Help! NO HEAT!!
Quote:
ORIGINAL: MattyNJ
worked that day, the next day didnt then did, and now doesnt!
check coolant AGAIN .. a low coolant level will not allow flow to the heater core and you have no heat.
although you THINK you filled the system, you probably did not.
Old 01-04-2009, 12:21 PM
thanks for the response, just ckd it again it looks full! how else can i put more in? I have the car running now with the cap off to see if it will circulate....anything else i can do?
Old 01-04-2009, 12:37 PM
its been running for 20mins or so, fluid level did not go down, its filled right to the top, NO HEAT FAN working??? I dont get it, thermostat??
Old 01-04-2009, 01:00 PM
Quote:
ORIGINAL: MattyNJ
not enough info ...
what doesnt work .. heat or fan?
thermostat? if that had failed, you be overheating, its fine.
are both upper and bottom radiator hose HOT ?
are BOTH heater core hoses HOT?
does the fan work if you turn on the AC ?
what is the engine temp ?
any codes ?
Old 01-04-2009, 01:10 PM
when the fan DOES come on the heat is hot, the fan only comes on when it wants to it seems, without the fan there is no heat??
fan dosent come on with either the AC or HEAT modes
radiator hoses are hot
engine temp is right in the middle
dont know about codes, i dont have diagnostic equip
Old 01-04-2009, 01:20 PM
Quote:
ORIGINAL: MattyNJ
fan doesnt come on with either the AC or HEAT modes
now we are getting somewhere ...
go to the FAQ section and learn how to pull codes, your car has built in diagnostics. it will talk to you about its ills and aches if you know how.
sounds like the coolant system is working OK.
fans .. connections or controller seems faulty. If it is intermittent, I bet on a connection being lose.
we got a FAQ thread called e-ghosts .. take a look at it.
Old 01-05-2009, 12:56 PM
Ok so i read the FAQ's section on E gosts and codes....I went and pulled the codes, wrote down only 1, as i had no idea how to repeat the list and they read off very quiclky...b1343 / Air inlet door movement fault....
FYI the heat and fan ARE working today....go figure???!!
I decided to also reflash the car, buy disconecting the batt cables, and leaving them dis conected for 20min as per the instructions in the FAQ thread....hoping this will re boot the electrical system errors????
Something tells me this is a moisture issue! under the back seat the carpet is very wet, i think the trunk or the sunroof is leaking.
Any other advice? Thanks for the help
Old 01-05-2009, 06:03 PM
Bet would be sunroof, drain hoses can be blocked by dirt or stuff that falls off trees.
Old 01-05-2009, 06:07 PM
Quote:
ORIGINAL: slowroll
where exactly are these drain holes?? just did some research, and was reading the same thing, and some ideas on how to blow them out or un clog them with wire....
Tech Help jkissam Cadillac Deville 0 07-16-2013 02:49 PM
tech help Robesp Member Introduction 0 11-28-2010 05:15 PM
Ok next prob. for TECH HELP.. MattyNJ Cadillac STS 7 01-06-2009 03:40 PM
1998 Cadillac STS won't heat the inside rodmayo Cadillac STS 6 12-07-2008 07:37 PM
94 sts tech help f4istunna Cadillac STS 2 10-03-2007 10:27 PM
Tags
1998, 98, ac, b1343, cadalac, cadillac, circulating, coolant, cooling, diagnosticsona2000cadilacstsheaterproblems, dont, fans, heat, radiator, seville, sts, work, working
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
