03-12-2007, 11:57 AM
2000 GM Cadillac STS 'SPEED LIMITED TO 145 K'(or 90 in the US) along with a blown fuse MESSAGE
I am wondering if anyone would be able to offer me advice. My 2000 STS has a message reading that the speed is limited to 145 k. I took it to the Mechanic and he spent 2 hours going over it to try and find the problem. He said that there was a blown fuse, he fixed but could not find anything else. Once the fuse was replaced the message disappeared, until I drove away from the dealership then it reappeared. He said he checked the sensors behind the wheels and that the shocks looked okay,he checked the wiring all looked good----he thought it to be a communication problem. Has anyone else had this message come up along with a blown fuse?? I have noticed that the front shocks seem like they have no air in them, but this has been for some time and this message has just come up along with blowing a fuse?
Moderator edit
title
03-12-2007, 12:56 PM
RE: STS 'SPEED LIMITED TO 145 K'(or 90 in the US) along with a blown fuse MESSAGE
Speed is limited in this way when there is a malfunction in the suspension control system. The PCM determines what speed to limit the vehicle to. Did the mechanic check any of the codes? Do you know how to retrieve the codes? Do you know how to reset the codes?Did the fuse blow again?
__________________
2006 DTS Performance - L37 32v Northstar NHP V8 292 HP - 1 of 1
1999 STS - L37 32v Northstar V8 300 HP
1998 Deville D'Elegance - LD8 32v Northstar V8 (Sold July 9, 2011 with 225,000 km)
1993 Fleetwood - L05 5.7 TBI V8 (Sold July 18, 2012 with 308,000 km)
1999 GMC Suburban SLT- 5.7 Vortec
1998 Olds 88 LS - Series II 3.8 V6
1973 Pontiac LeMans GT - 454 V8 1 of less than 5
03-12-2007, 01:11 PM
hi
Thank you for your response. Yes the fuse did blow again as I was driving away from the dealership and that is when the message reappeared. I did check the codes the first time prior to taking it in and there was C1252 and C1253. I am wondering if the fuse blows to limit the speed when maybe the shocks fail? Although the mechanic said all is well with the shocks, I feel the shocks are not performing well, it is as if there is no air in them. I will go to the car and check to see what codes are showing now. Would this help?
03-12-2007, 01:14 PM
hi
03-12-2007, 01:28 PM
I just checked to see what the codes are now and they are
ABS C 1252 current
ABS C1253 current
U1056 History
U1000 current
No Amp codes
No DDM codes
DIM U1016 History
PCM P1652 Current
TTM U1016 History
These are all the codes showing. It may be that the fuse is not blown again, but the message is up.
Would anyone know what this could be or has had the same codes and problem
03-12-2007, 01:30 PM
These are the code descriptions:[*]C1252 - Left Front Normal Force Malfunction[*]C1253 - Right Front Normal Force Malfunction
A fuse that continually blows usually indicates a short imo. I think that a recheck of the codes would be helpful.
__________________
03-12-2007, 01:37 PM
[*]P1652 - Powertrain Induced Chassis Pitch Output Circuit[*]U1000 - Class 2 Communication Malfunction[*]U1016 - Loss of Communications with PCM[*]U1056 - Loss of Communications with RSS
Well the mechanic is right, you have a communication problem, but why is the question. I think you should check the fuse. I would not suggest erasing the codes because the mecahanic needs to see them.
__________________
03-12-2007, 01:55 PM
thanking you for your response. what is a short imo?
The mechanic has spend 2-3 hours trying to find the problem and is unable--the message still comes up and the car limits my speed to 145k. It has cost me 210.dollars and they have no clue as to why this is happening. So I thought maybe someone else on here might have had the same problem and it may save me from letting a mechanic spend another 2-3 hours or more and still not finding the problem
03-12-2007, 02:08 PM
"a short imo" sorry about that, means that there must be an electrical short circuit in the system In My Opinion (imo)
__________________
03-12-2007, 02:15 PM
Thank you
Tags
1993, 1998, 38, c1252, c1253, caddy, cadillac, code, codes, deville, olds, reset, srx, sts, u1016  |
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
