08 STS. 2 types of TPMS?
Old 07-16-2016, 01:00 PM
coach555's Avatar
Default 08 STS. 2 types of TPMS?
My TPMS on my right front tire died this week . I was at a tire store today and they tell me they have a programmable and a non programmable sensor in stock. Which one do I need to buy? Of course the non programmable senor is a lot cheaper. The tire store said they cannot tell until they have the old sensor in hand. I presume that the tire sensor will be the programmable one. Is there a way to tell without having the old sensor in hand ?
My Cadillac is an 08, STS4 with the 4.6 North star engine. Has the factory Nav. in it
Plus If my sensors are programmable, When I rotate the tires do I need to get the sensors reprogrammed ?
thanks
Old 07-17-2016, 09:39 PM
Go to dealer and get correct one. Dealer will look it by VIN to insure you get correct part. The outside bead of tire needs broken down to install. Balancing may not be required.
Yes sensors need to be relearned when tires are rotated. Check owners manual for procedure.
Old 07-18-2016, 11:55 AM
coach555's Avatar
Will do. I was trying to stay away from the dealership seeing their cost is more expensive than a tire shop. I wonder if the sensors OEM number would cross match to an aftermarket sensor
Duffdaddy
05-07-2014 05:17 PM
green1
01-04-2010 03:34 PM
LucMolenaar
10-19-2009 10:34 AM
92_Daddylac
04-13-2009 05:37 PM
trakspeed
10-27-2007 01:14 PM
Quick Reply: 08 STS. 2 types of TPMS?
