04 SRX slow starting problem
Hi Guys, my wife has an 04 SRX V8 and loves it. The only trouble we've had with it is the CD changer and recently a starting problem. The car always starts eventually but the problem seems to be getting worse. It has been to the dealer twice and still has the problem. Anyone know what the problem could be?
RE: 04 SRX slow starting problem
ORIGINAL: TA76
Can you describe what you mean by taking three tries to start?
Exactly, how long do you crank on each try and what happens ?
What has been done since the problem surfaced?
other details are needed per this thread:
At any case, I'm thinking two options .. expensive, so we need details.
1. coil pack
2 fuel pump / fuel pressure.
The dealership has cleaned the injectors twice I believe. Sometimes the car starts just fine on the first try. Most of the time it takes two or three attempts to start. By that I mean it just turns over and over (around 15-20 seconds) until it stops or you turn the key off. Until recently, it would then start on the second attempt like normal (pretty quick). In the last month or so it is sometimes taking three attempts to start. The car always starts but it somewhat irks the wife that her 50K car won't start the first time like my 26K Colorado.
Edit-Let me call the dealership and find out exactly what they did both times it was in the shop for this.
ORIGINAL: TA76
Why clean the injectors? That is not even on my radar.
Did they do a FUEL PRESSURE TEST? what was the pressure?
Cranking once and not starting, cranking a 2nd time and starts quickly .. points to a failing fuel pump and a far second, the coil pack.
Now its evolved to three times? now coil pack gets to the lead but fuel pump remains a close second.
I'm still thinking .. why clean the fuel injectors? odd. Cant wait for what they say on this one.
Try these two:
1. you turn the key on but do NOT crank and listen to the fuel pump .. time it until it stops. Turn key off for 10 seconds. repeat .. time again. get back and report ...
2. IF the time is equal on the 1st and 2nd attempts, try this:
when the engine is cold .. hit the coil pack with 5 minutes of really hot air, using your wife's hair drier.
stop the hot air, close the hood and start her up .. report ...
The other TECHS may want to skin me for unconventional methods .. but, what you have, I been there, done that.
2001 DEVILLE MOAN IN TURNING AT SLOW SPEEDS, REAR SHOCK ADVISE HELP, AND VIBRATION AT HIGHWAY SPEEDS
jd3772001
07-12-2007 09:31 PM
