Starting Problems!!!!!!!!Help!!!!!!!
[:@]I have a 95 sts, recently when I turn the ignition to the on position, the check engine light comes on, the screen reads traction disabled, and the cooling fans come on full blast,and the car won't start. The only way to start the car is to turn the ignition on and off several times until the check engine light doesn't come on, after that the car starts fine and runs like a top. None of the repair shops seem to know whats wronge with it, and the dealer wants $85 an hour just to check it out! So if anyone has had this problem please help.....thanks.
RE: Starting Problems!!!!!!!!Help!!!!!!!
ORIGINAL: muzik4life
check these threads, there is probably most of what you need in there.
The BEST car Cadillac ever made is the .. you get to pick.
https://www.cadillacforum.com/m_9438/tm.htm
MY Cadillac has more miles than yours thread .. Lets get the 400,000 mile cars.
https://www.cadillacforum.com/m_12353/tm.htm
CODES .. Pulling & understanding CODES .. we need CODES to help you.
https://www.cadillacforum.com/m_18197/tm.htm
https://www.cadillacforum.com/m_17425/tm.htm
https://www.cadillacforum.com/m_11904/tm.htm
Community Services: Auto parts, Vehicle Taxes, highways cams, picture capture,
Corp 800 #’s, unique shipping services .. etc ... take a look.
https://www.cadillacforum.com/m_9880/tm.htm
Average age of our Cadillac owners .. where everyone says they are 23.
https://www.cadillacforum.com/m_931/tm.htm
Why you should change to coolant the day you buy the Cadillac.
https://www.cadillacforum.com/m_7193/tm.htm
https://www.cadillacforum.com/m_7388/tm.htm
Transmissions or Engines - why you do NOT FLUSH the 4100 & 4500 drive trains.
https://www.cadillacforum.com/m_6036/tm.htm
Cadillac GM e-ghosts electric problems, intermittent codes, etc.
https://www.cadillacforum.com/m_6068/tm.htm
Help from our TECHs ? You really want to read this.
Cadillac TECH FAQ MENU .. pull up all the FAQ topics
https://www.cadillacforum.com/m_6733/tm.htm
Cadillac Technical FAQ section .. everything Cadillac
https://www.cadillacforum.com/forumid_64/tt.htm
Cadillac Allante TECH FAQ .. things that the car needs often, owner’s manual, etc.
https://www.cadillacforum.com/forumid_83/tt.htm
The Cadillac Allante Pub - discuss, argue, and laugh .. Allante not needed to jump in.
https://www.cadillacforum.com/m_21055/tm.htm
Allantesource.com Allante PROCEDURES MENU .. issues that few know how to handle
https://www.cadillacforum.com/m_18287/tm.htm
Hobby Corner .. Hot wheels, trains, whatever ..
https://www.cadillacforum.com/forumid_60/tt.htm
Cadillac History .. The real McCoy, from day one.
https://www.cadillacforum.com/m_6356/tm.htm
Welcome to CadillacForuM.com
Fleetwood82
12-09-2006 06:52 AM
