Starting
Old 09-25-2009, 02:09 PM
Big Jake's Avatar
Default Starting
My 1997 SLS has 108,000 miles on it and is hard to start after setting overnight. I have to try it 3 or 4 times before it will start. Once started it will start all day just fine.
Any suggestions? I haven't tried anything yet.
Thanks
Big Jake
Old 09-26-2009, 09:26 AM
Fuel pressure regulator - check for fuel leaking at vacuum port.
Old 09-26-2009, 08:40 PM
92_Daddylac's Avatar
also try to change out the fuel filter if it hasnt been changedthey're cheap too. some times if a dirty fuel filter sets overnite the debris in the fuel filter clogs it up and then it makes it harder to start and once you try it a few times it not necessarily unclogs it but pushes some of the debris through. after you change it check pressure if it increased from before.
Old 10-09-2009, 07:37 PM
Big Jake's Avatar
Thanks to Slowroll and 92 Daddylac.
I finally went to a friend, who is a mechanic, and he found out it was the fuel pump.
Since the fuel pump is in the fuel tank is was not an easy fix.
Big Jake
macarose
04-17-2010 07:35 PM
muzik4life
05-17-2008 12:23 PM
japanesemike1988
08-31-2006 11:29 PM
anto915
07-25-2006 11:26 PM
jerzey21
02-05-2006 09:09 PM
Quick Reply: Starting
