PCM code P056
RE: PCM code P056
Hmmm.....that is the transmission input speed sensor. $20 part $2000 deep into the trans. It is NOT the VSS sensor.
You can check the transmission connections, also, note, that spark plug wires resting on any part of the engine harness can cause a false code.
Logan Diagnostic
www.airbagcrash.com
www.ledfix.com
www.logandieselusa.com
Logan Diagnostic
www.airbagcrash.com
www.ledfix.com
