Go Back   Cadillac Forum - Enthusiast forums for Cadillac Owners > Cadillac Models > Cadillac Seville
Sign in using an external account
Register Forgot Password?
Search
LinkBack Thread Tools Search this Thread
Old 12-10-2006, 08:33 PM
Default key fob programming instructions
came across this, maybe this will help out...this is for analog gauges....
With the ignition in the "RUN" position (engine does not necessarily need to be running, but it will work either way).
Press OFF and WARMER (or the OFF and PASSENGER WARMER buttons) on climate control panel simultaneously. Instrument Panel Cluster (IPC) will light all telltales, then go blank. System is now in DIAGNOSTIC MODE. After diagnostic mode cycles through and stops, press FAN DOWN button until "RFA?" is displayed, then press FAN UP. If "RFA DATA?" is displayed, press FAN DOWN. If "RFA OVERRIDE?" is displayed press FAN UP button.
If "RFA S00 NO OVERRIDE" is displayed, press FAN DOWN. If "RFA S01 PROGRAM FOB #1" is displayed, press FAN UP button.
IPC will show "0" on right side of Drivers Information Center (DIC) display. Press WARMER button on the climate control unit until "99" is displayed.
Press and hold TRUNK button on the transmitter. While holding TRUNK button, press LOCK button and hold both buttons for a total of 3 seconds. Locks will cycle when programming is complete. If transmitter is not programmed within 30 seconds after entering "99" on the display, system will default and you must begin at step #2 again.
To program second transmitter, press FAN DOWN button until "RF S02 PROGRAM FOB #2" is displayed, then press FAN UP. Repeat step #4.
To exit system, press AUTO, MODE UP, MODE DOWN, or RESET button.
__________________
1996 Seville SLS
Tags
2000, 2006, cadillac, deville, dts, fob, instructions, key, program, programing, programming, seville, srx, sts, transmitter
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
