I need help! My 94 seville sts overheats
My 94 seville sts overheats. Ive checked for blown head gasket,they are good water pump is good, radiator is not plugged and I have even tried to bypass the heater core it still overheats. the top radiator hose gets wicked hot but lower doesnt get hot,the thermostat is new. does anybody have any other suggestions.
mod edit
title
mod edit
title
pull the stat and see how she runs then.
where did you get the PUMP ?
Ok I tried removing the t stat and still the same. i bypassed the heater core and just left the the hoses going to the core wide open and no water came out of them when running, but the car still got hot.Could the head gasket have failed even more since it was first tested or is there anything else i should try.Prior to all this the car always ran at 199 moving and 200-220 at a stop, then one day at a stop the temp climed to 240 then i shut it off.
pull the top hose and run the engine .. if coolant does not come out like a geyser, your pump is either dead of defective.
not sure if you can tell that at the heater core but you will know for sure at the rad side.
ok so fari have i have done everything and it all looks normal, but the water pump looks like its not flowing enough water so i put everything back the way it should be but broke a bolt off in the thermostat housing so im taking a break from the car for a day thanks again for all the help
