98 Seville water in trunk
bought car in winter and noticed ice covering spare tire in trunk. removed ice, but water remains after vac***, and air dry. power door locks, rear defrost, rear seat heaters, gas gauge, open trunk button, and gas door button stopped working. Dealer says water got under rear seat and I need new computer(?) there and in driver side door.
How do I figure out where trunk is leaking? or possible rear window? can this be repaired simply? will the electical stuff start working again once kept dry for awhile? read in this forum about possible ground wire causing elec problems...I don't trust the dealership.
RE: 98 Seville water in trunk
When I purchased my 2003 STS, it had the same issue. There is a bulletin on the issue involving the welds and seals of the trunk floor pan. My car was fixed under warranty. You may want to get a copy of the bulletin to see what is required to fix the problem
guintiger
01-11-2018 07:05 PM
