CPS and P0171 and P00174
Old 01-01-2013, 12:12 PM
roho's Avatar
Default CPS and P0171 and P00174
2003 Cadillac Seville.The codes are P0171 & P0174. Also cutting out at low speeds. Had the same two problems over a year ago. Was fixed by replacing the intake plenum coupler and the CPS. Are the two related? I'm just confused why I'm having the same two issues again at the same time. Any ideas?
Old 01-04-2013, 10:05 AM
92_Daddylac's Avatar
If the P0171 is combined with the P0174 code, it's very likely that the problem is caused by an intake leak. If there are no intake leaks, the next step is to replaced the air filter and clean the air flow meter. If the problem persist the front oxygen (O2) sensor may need to be replaced.
ranjit
10-13-2012 12:10 PM
rukor208
02-02-2011 10:11 PM
2001slswhite
05-21-2008 10:04 PM
eechapa
11-02-2007 09:07 PM
chattycat
10-11-2007 08:02 PM
Quick Reply: CPS and P0171 and P00174
