Coolant leak
Old 04-19-2009, 07:24 PM
STS99BL's Avatar
Default Coolant leak
My car has sat for a week, then I noticed a leak the other day and added coolant and cleared the "check coolant level" on the dash. I have a coolant leak/drip coming from the center of the motor. It seems like its dripping off a black plate thats right in front of the oil pan. I had it pressure tested and everything turned out ok, no leaks were found. Any chance it came out cuz I put in to much?
Thanks
Old 04-20-2009, 12:03 PM
Thanks
that could be,........ id watch close. have you exchanged coolant lately?....... you might have a hose/ connection loose, or bad. i'd check those also.... good luck and keep us posted
Old 04-21-2009, 08:58 AM
STS99BL's Avatar
I have not changed it yet, although it was changed before I bought it last October. I checked it today and everything seemed ok.
cady97dev
Aluminum Block V8s
03-20-2009 08:10 AM
lferrebee
08-23-2007 04:36 PM
strabo40
12-11-2006 01:47 PM
mxblue23
03-13-2006 04:28 PM
mxblue23
02-28-2005 04:41 PM
Quick Reply: Coolant leak
