1997 SLS - Coolant Replacement
I'd like to replace the radiator coolant, but there is no drain plug on the radiator that I can find. Is there a trick to this? I saw one posting that said the easiest way was throught the water pump, but had little instructions for that process. Is there a special too required for this as well?
RE: 1997 SLS - Coolant Replacement
I'm in the same boat...
I have a 98 SLS that needs new coolant.
I just bought a Prestone flush-n-fill kit.
After I find time, I'll reply. I hope it's not messy???
Also before I do-it-myself, I need to find a place to recycle it, or take it to???
It might be more of a hassle to DIY than just let a station deal with the fluids???
ORIGINAL: djberger
cady97dev
Aluminum Block V8s
03-20-2009 08:10 AM
revelation1
01-04-2009 03:08 PM
