ABS problem
ABS problem
Hi, having ABS/stability/traction problems with my 99 SLS. Codes are C1242, C1243. From what I've been reading, bad ground connections are the first place to look especially at g100 & g102. Where are these ground connections located? thanks
other than the battery grounds, you need a manual to find them all ..
looking for a used abs and connector for 1995 seville sls 4.6
Basically the original ABS in our 1995 sedan Seville SLS shorted out.
The unit and connector seem to lie directly below the thermostat connection from the radiator, go figure. When replacing the lower radiator hose the ABS shorted out, my theory, water and electricity don't mix.
ABS update
Turned out to be a bad pump and/or controller. I'm not spending $2500 to fix it. I can get an ispection sticker with the ABS light on. My only concern is that I would prefer not to start out in second gear all the time. Is there anything I can do to overide this? Thanks
