1995 cadillac seville sls SHAKING!
Old 02-18-2012, 08:40 PM
mexlokote's Avatar
Exclamation 1995 cadillac seville sls SHAKING!
i recenlty bought a cadillac sls and the odometer reads 55,xxx miles i had it for about one month and it recently started to vibratewhen i start it up it works fine when when i change to {D} or any gear it starts to vibrate like if i were pressing gas and brake at the same time like wanting to take off if i take the brake off, i drive it and the vibration stops but when i go around 40MPH it starts to vibrate again like if it cant go faster and i press on the gas and i get this knock on the bottom of the engine like if something were hitting it i just changed the sparkplugs n oil also brakes, the rotors are fine i just want to know what this is... any suggestions?
Old 02-24-2012, 07:46 PM
unc2330's Avatar
no way to tell for sure until you look inside, but sounds like you wana get that checked asap
Old 03-18-2012, 03:02 PM
Love_tk1's Avatar
i would get it checked out. the knocking might be somthing with the rods and pistons. either way, it is no bueno.
Old 03-31-2012, 02:34 AM
Love_tk1's Avatar
come to think about it, you might need motor mounts. they are kinda inexpensive, if you own an engine hoist. if not, it could be expensive depending where you go.
Old 06-12-2014, 08:53 AM
sharif's Avatar
Dear Forum members..
I am new to this group.
I got a 20 yr old cadillac recently. 1995 cadillac seville STS. The car is running fine but in the display board it shows service ride control. But I don't see any problem while driving and have been driving the car for the last 4 months.
Is it ok to ignore this problem?
Please do suggest me. I am really new about this car.
I really appreciate your time and help.
Regards
Sharif
Old 06-14-2014, 09:55 PM
you should have started new thread or post. Your problem doesn't relate to this one. Start new post with this concern. A code(s) should be stored if message is displayed. FAQ section will tell you how to get codes. Related codes will be RTD codes should start with "S"
CtsAlbert
08-13-2013 01:43 PM
nelson480
08-07-2011 11:04 PM
shahaf
07-03-2009 04:11 PM
shahaf
07-03-2009 04:09 PM
hotleonard
07-18-2008 06:20 PM
Quick Reply: 1995 cadillac seville sls SHAKING!
