how do you remove heater hose connector that connects to engine?
Old 12-12-2007, 11:46 AM
cortewardy's Avatar
Default how do you remove heater hose connector that connects to engine?
Hello, my car is a 98 cadillac seville sts ...Im having trouble disconnecting the heater hose connector that screws into the rear of the engine, just above the transmission.I have included a picture of what the connector looks lsike. Im looking for any information regarding the removal of the connector, as it is hard to get to, do I have to unscrew it from the bottom of the car or can i take off some stuff from the top of the enign so i can get access to the screw connector from on top of the engine. any help will be gladly appreciated thanks!
[IMG]local://upfiles/4871/E08860828A054D0A9D1B8E72CAAF51D4.jpg[/IMG]
Old 12-12-2007, 06:11 PM
Default RE: how do you remove heater hose connector that connects to engine?
If nipple is broke off, crossover has to come off. To remove nipple take egr pipe loose and disconnect heater pipe. Deep socket and ratchet should take it loose.
LtDan
10-04-2011 10:50 PM
lkguffey60
11-08-2009 08:47 AM
schlicky13
10-20-2009 10:43 AM
etaylor
01-20-2008 11:13 PM
bighank
12-13-2007 07:21 PM
Quick Reply: how do you remove heater hose connector that connects to engine?
