Soft/Hard top pull down Motor
Went to latch my soft top and when the pull down motor got to "Bottom" the pull down motor kept running. Unlatched the soft top and the latch asy. did not return to top, however the soft top released. I pushed down on the switch within the latch asy. and motor stopped - Let the switch return motor kept running and latch would not return to uppermost position.
I am thinking acuator is fried, but hoping for a miracle. I have note answered or posted for about a year and though there was one or two threads but could not find them.
Thanks!
Yogi
Thanks!
Yogi
Thanks!
Yogi
Thanks!
Yogi
what happens then?
When I disconnected the two wires from the soft top switch, the pulldown motor stopped running. I tried to cycle the latch using the switch and I could not get the motor to engage when I applied pressure to the up side of the switch. The motor would only run when I was applying pressure to pull the latch down. I grounded the black wire at the soft top position and the motor kept running.
More suggestions?
Thanks!
Yogi
More suggestions?
Thanks!
Yogi
