COOLING FANS
Old 03-20-2007, 12:11 PM
drew13's Avatar
Default COOLING FANS
IS THE SYSTEM ON 93 ALLANTE [2 FANS 3 RELAYS] THE SAME ON ALL CADILLAC CARS WITH NORTHSTAR ENGINES
Old 03-20-2007, 09:37 PM
G.A.R.Y.'s Avatar
Default RE: COOLING FANS
My N* experience is related to the 93 allante only, however I will find someone here, or find the info myself to help you with your question.
Old 03-20-2007, 09:47 PM
w/o knowing the answer, i would get the PART #'s and get your local dealer
to cross reference them and see what other GM cars use it.
you can do the same on line with a GM parts house.
i assume you are looking for parts from other cadies that fit a '93?
if so, the local salvage yard has the cross references you would need.
ORIGINAL: drew13
Old 03-21-2007, 12:52 PM
Katzmans Caddy's Avatar
http://www.shop.com/op/~Dorman_Radia...91?xit_recnt=1
This parts listing shows interchangeabilty acrosss all lines from 93-2000.
Old 07-15-2012, 07:32 PM
acsnowrider's Avatar
How about the 1992?? Diff/Same system???
Old 11-06-2012, 10:07 PM
Edwards0's Avatar
Today i come back to this community and want to ask something special relating to your topic which is that I am trying to put cooling fans on the back of my enclosed entertainment center to help cool things off because the temperature is getting up to 145 degree fahrenheit. If anything can I get the schematic to build the cooling system myself from scratch.?Any Ideas which would be appreciated.
Joe_SLS
09-01-2012 08:30 PM
rustyboltz
07-17-2010 10:46 AM
skyzzics
09-18-2009 10:15 AM
Tater50
04-30-2009 07:05 PM
2BUD
09-02-2008 11:27 PM
Quick Reply: COOLING FANS
