Cadillac Allante HeadLamp condensation
ORIGINAL: Yogi
Condensation in the right frt. headlamp, weep hole and hose clear, Suggestions?
Make sure the vent hose is in place and points down.
If you must know where it leaks or to check it when the job is done, fill it with water and check for leaks around the seals of the two haves.
Use long medical Q-Tips dipped in Stoner's Invisible glass to scrub the inside of the lens.
If the lens is opaque, do a restoration per this thread
https://www.cadillacforum.com/m_8686/tm.htm
Also, check that there are rubber washers where the bulb holders fit into the capsule.
All along, remember that the going rate for these Allante headlights is $700 new, $350 used - EACH.
Darn well worth the effort.
This works for just about any headlight and tail light assy of just about every modern car on the road.
gr8guy@cox.net
05-28-2009 11:22 PM
Yogi
11-21-2007 10:58 PM
