rusty hinges 1980 Fleetwood
Old 03-30-2008, 08:39 PM
dwpnz's Avatar
Default rusty hinges 1980 Fleetwood
I need to replace my door hingeson least one door on my 1980 Fleetwood brougham. Does anyone offer any replacements that are good quality or should I hit the parts yard? Are there any other Cadillac models ( or other GMs) that will interchange?
Old 03-30-2008, 10:27 PM
brougham1's Avatar
Default RE: rusty hinges 1980 Fleetwood
Hinges are available at www.usapartssupply.com and they are a little pricey but if you need them and want new it will save you a lot of time.
Old 03-31-2008, 08:30 PM
dwpnz's Avatar
Thank you for the help. I will check it out.
Old 04-02-2008, 02:33 PM
carnut's Avatar
This is a "B" body GM car I believe. So a full size Olds 98, 88 or a large Buick or Pontiac uses the same hinge.
Old 04-02-2008, 05:50 PM
dwpnz's Avatar
That makes sense. It was too obvious for me to think of. Thanks. To Cadillac heads are better than one, right?
Old 04-03-2008, 11:30 AM
carnut's Avatar
These cars also can provide door switch panels, mirrors, radios, and stiffer suspension parts, windshields, door glass and different wheels.
Old 04-03-2008, 05:10 PM
dwpnz's Avatar
Stiffer better handling suspension? Which models? Buick possibly the La Sasbre? Thanks for the input.
Old 04-03-2008, 06:43 PM
carnut's Avatar
Yes the le Sabre. They made a turbo V/6 version that I used for the rear sway bar to upgrade my Olds 98 years ago. Turbo bubble hood might fit?
Old 04-03-2008, 08:19 PM
dwpnz's Avatar
Turbo bubble hood? It might look good and would be different. It could possibly clear an aftermarket fuel injection system for the 500bb I have and am dying to build.I like where this is going. Thanks.
cadithings
11-17-2008 04:35 PM
rodnkustoms
10-14-2008 08:17 AM
bearman
08-26-2007 12:20 AM
brian321
02-24-2007 02:52 AM
serge
05-13-2005 04:55 PM
Quick Reply: rusty hinges 1980 Fleetwood
