Overheating Brand New Radiator
Old 02-28-2012, 10:50 AM
cbailey's Avatar
Default Overheating Brand New Radiator
I just put a brand new radiator in my 1994 Cadillac Brougham and it's still overheating? It was leaking now it's spitting out anti-freeze.Can someone help me.
Old 02-28-2012, 12:25 PM
Cadsforfun's Avatar
Default overheating
Was the thermostat replaced at the same time?? Are the top and bottom hoses both getting hot??
Old 02-28-2012, 06:38 PM
Henry Leland's Avatar
^^^ X2, definitely check the thermostat, it might be stuck closed. Does it overheat while moving, or only when stopped with the engine running? Have you checked the engine timing? (If may run hot if the timing is too advanced.)
It is blowing coolant out of the radiator cap? Try a new cap; if it's old the spring may be too weak to hold at normal operating pressure. If both the thermostat and the cap are okay but you're still getting coolant out of the cap, there could be a blown head gasket letting high-pressure combustion gases into the cooling system, which can force out coolant. (Hopefully from the cap, and not a crack in your new radiator.)
rukkus
03-02-2011 06:23 PM
bcop
02-18-2008 09:40 AM
Cadillac Man
03-10-2007 01:26 AM
spoiled by caddy
12-02-2006 05:15 PM
eds9c1
12-05-2005 10:33 PM
Quick Reply: Overheating Brand New Radiator
