A Leak of Coolant
A Leak of Coolant
I have to refill my anti-freeze constantly in my car and I need it in order to be able to use the heat. Well recently my brother brought home a tool he uses at work since he works at a GMC Gendrons Truck Repair shop. Well he attached it to my radiator and pumped air into it and you can follow the hose and notice a leak coming from it. I don't know if a new water pump is required or just a new water hose is needed,I drive a 91 Fleetwood Sixty Special FWD if pics are needed I will post some,Thank You
why would a water pump be needed if hose is leaking?
if a hose is leaking, replace the hose.
if the radiator is leaking, replace the radiator.
maybe i dont understand the problem?
cady97dev
Aluminum Block V8s
03-20-2009 08:10 AM
