interior lights stay on
Old 10-07-2008, 04:33 PM
89whitefleet's Avatar
Default interior lights stay on
My good friend has a 95 fleetwood and the interior lights will not turn off, so he has removed the fuse. What could it be???? Please help. Thanks
Old 10-08-2008, 12:43 PM
carnut's Avatar
Default RE: interior lights stay on
Headlight switch rotated all the way to interior lights on? earlier GM cars would do this if tin foil or a dime etc were under a cigarette lighter, blows the 20 amp courtesy fuse, feeds back thru the dome lamp circuit and the lights stay on dimly.
Old 10-25-2008, 09:53 PM
Katzmans Caddy's Avatar
Door jam switch malfunction. I just replaced one on my Suburban, $8 at the dealer.
Old 10-26-2008, 10:45 PM
1989 fleetwood's Avatar
i have a 94 fleetwood and had the same problem where my interior lights wouldnt go off. It ended up being a loose ground.
Old 02-16-2015, 10:47 PM
Gustavo Facio's Avatar
Default what ground?
Do you know exactly what ground?
Old 08-11-2016, 10:50 AM
Anita Mae's Avatar
Unhappy Lights stay on
Can you tell me where the fuse was located? I am having the same issue. Running battery down.
Old 08-11-2016, 12:02 PM
Do you have owners manual?
Old 08-11-2016, 12:42 PM
Anita Mae's Avatar
Unhappy Ground
Someone said lights staying on ended up being a ground. Can you tell me what ground and where it is located?
Thanks so much for your help.
Old 08-11-2016, 12:47 PM
Anita Mae's Avatar
Unhappy Slowroll
Yes, I have an owners manual. But was unable to locate an interior light fuse.
This owners manual reads like a Manual for "Dummies" who have never been taught to drive. Talks about how to operate windows, how to put in gear what to do if going through high water, how to change fluids and put gas in, even how to clean it inside and out. But not a darn thing on interior light fuses.
Old 03-08-2017, 06:29 AM
425-dual-quad's Avatar
Thanks - have the same issue - small cupboard light type switch attached to the door lock? Couldn't find one anywhere last year. What part number please and what dealer? Does it fit the 93-6 FWBs?
Thanks Nick
Quick Reply: interior lights stay on
