heated seats
Old 10-02-2008, 06:22 AM
1989 fleetwood's Avatar
Default heated seats
the driver side heated seat in my 94 fleetwood dosent work. The passenger side does but not the driver. I know it could be differennt things that are wrong with it but abouthow much do you think it would cost to get it fixed? and is there anything i can check on it?
Old 10-02-2008, 09:00 AM
Katzmans Caddy's Avatar
Default RE: heated seats
Now that I have a similar car I better get studied up on what goes wrong. Generally the heating elements go bad in the seat or become disconnected since it is the seat with the most use. Could be a wiring problem, switch problem or the element, the element being the most costly and troublesome.
Old 10-02-2008, 10:32 AM
Theres a light onthe switch where you can select low or high. When i switch it the light comes on. Does this mean that the switch is good? Im about to pull up a wire diagram and dig a little bit deeper. I do live in florida but When it drops down to 65, im ready for the heat.
Old 10-02-2008, 12:41 PM
I'd say you have power to the switch in that case but the light could be unrelated. I've had window switches that won't work but the illuminatiion still came on.
elucas
10-11-2012 05:23 PM
andyg16
07-24-2009 04:51 PM
rufrydermg
12-28-2007 07:07 PM
satch
09-28-2007 12:30 AM
edtherock
12-20-2005 03:37 PM
Quick Reply: heated seats
