Check engine light/codes
Old 07-13-2009, 09:36 AM
89whitefleet's Avatar
Question Check engine light/codes
My check engine light is on (89 brougham). How do I get the codes??Possibly without having to go to the mechanic. Thanks
Old 07-13-2009, 10:44 PM
Katzmans Caddy's Avatar
Go to this link, it tells you how to get the codes:
http://myweb.accessus.net/~090/dtcobd1.html#ide
Old 07-14-2009, 09:46 AM
Thanks, but I tried that prior to my post- and it does not work. I can not seem to get the codes. I believe I read somewhere else it can not be done through the climate control on a 89 fleetwood brougham.
Old 08-09-2009, 03:51 PM
sven914's Avatar
It can't be done through the climate head on the Brougham. You have to jump the last two terminals (toward the passenger side) on upper row of the ALDL. You can use a paper clip.
When you jump the terminals, turn the ignition to the run position, but DO NOT start the engine. The check engine light will begin to flash a two digit code. The first code will be 12 and will be presented as 1flash/pause/2flashes. Each code will flash 3 times.
Go to http://www.extreme-check-engine-ligh...%20Decoder.htm for a complete list of the codes.
Drama
10-06-2020 09:45 PM
calvinamen
09-24-2014 08:34 AM
maxximillion
07-02-2014 08:10 PM
99CaddyNH
07-17-2008 06:36 PM
Quick Reply: Check engine light/codes
