CAR WONT START
Old 08-13-2007, 01:36 PM
coocadi's Avatar
Default CAR WONT START
Hey guys, hows everyones cadillac doing?
Go to start my 94 Fleetwood and it wont turn over, later in the day when it warms up it will start after a couple tries. Just changed the sparkplugs. It runs fine when you accelerate slowly, but put the petal to the metal and seems like it stutters and shakes alot? Fuel filter? Cold start valve? I wish I hadnt sold my 96 Towncar for this car
Old 08-20-2007, 01:51 AM
coocadi's Avatar
Default RE: CAR WONT START
came up with these codes :
-55 is Fuel Lean
-46 is Pass Key fault
-44 is Left heated oxygen sensor (Lean Exhaust Indicated)
Old 08-20-2007, 09:42 AM
was it running ok before? what was done before the problems started?
please read this thread:
Old 08-20-2007, 11:12 AM
coocadi's Avatar
OOPS! I should've read that before, thank you!
Hello Cadillac guys.The car is a 94 Cadillac Fleetwood Brougham, picked it up with 119k miles for $3,600 about 4 weeks ago. Always ran fine, seemed a little hessitant when I would floor it, almost like it was dieing, but it would pick up. Me and my father changed the spark plugs with bosch platinums. It started up and was fine, the next day, it wouldnt turn over, it sat there for a week, everyday I would go out and try to start it, finally had some luck when I gave it gas and turned the key, let it run for 10 min. and shut it off. 2 hrs later started right up. Once I get it started after some trouble, it will keep starting, as long as I dont let it sit for too long. Its been like this for 2 weeks, one time at night, Im turning a corner and it dies on me, I started it back up and it ran rough until I put gas in it, the tank wasnt low according to the gauge.
Like I said here are the codes, im going to take it to a mechanic and have them do a diagnostic for $65.
-55 is Fuel Lean
Thank you for any help, I like this site, just wish there was more Fleetwood owners.
Old 08-25-2007, 11:00 AM
coocadi's Avatar
Well, took it to my mechanic, replaced ignition coil, distributer car and rotar. Runs swell, now the "Low Coolant" light is on.
Old 12-10-2007, 06:43 PM
HMM, Might be your fuel pump or maybe your fel filter as well. I would recommend you replace your feul filter first. That is cheaper and easy. Also get a can of Sea foam engine treatment. You willl be suprised at the benefits you will get after adding that stuff to your gas tank. Good Luck!!!
dirtylow
01-19-2022 10:13 PM
RSchaeff
08-10-2014 02:24 PM
Jack West
11-12-2012 11:07 AM
TKHAWK
10-03-2011 04:52 PM
royalet
04-07-2011 02:04 PM
Quick Reply: CAR WONT START
