93 BROUGHAM!!!LEAKING
I finally purchase my cadillac..I bought a 93 brougham 5.7L 350..Beautiful red on burgundy leather top with only 86,000 on it for $4500..Thats besides the point..I had 2 drive about 40 miles to pick up but it was worth it..next to the fire wall behind the end of the front passenger carpet I notice there is water leaking in through it when I got home ..Plus my light tail light at night doesn't turn on but it does when I apply brake..Any help please thanks sorry for the long story
RE: 93 BROUGHAM!!!LEAKING
Slowroll !!!I wipe the water with white rag and it seems pretty clear...I also got the dash lights workin ,it was a faulty fuse in the engine compartment..I check them all with a electrical fuse tester..But now for some odd reason my milage and mph gauges doesn't run but is on..
Pcm send data to cluster for speedo. No ses should mean pcm is getting signal from vss, and problem is pcm,cluster or wires between them. you will need to take to shop or guess with your money.
