4.1 engines
Old 05-26-2009, 06:33 AM
bobfeder's Avatar
Default 4.1 engines
Is it true you can eliminate most of the problems on it by putting a hight voltage dist and wires with bosch plugs. Because they tend to carbon up using original? Did they have a valve problem that you have to use motor honey in it? Minew is popping through carb and code says rich mixture.
Old 05-26-2009, 07:59 AM
havent heard any of that.
also, there are several versions of 4100 engines, so year made is important.
Old 06-05-2009, 08:15 PM
carnut's Avatar
Number one it has no carb!! number two, popping thru the throttle body usually means a damaged, flat camshaft. that requires an engine replacement. This car already has a high energy distributor and wires.
mr_udy
01-13-2007 07:27 PM
Raganl
07-07-2006 02:53 PM
81slantback
03-06-2006 07:06 PM
Quick Reply: 4.1 engines
