1993 fleetwood passkey fault 01-43
Old 03-22-2007, 01:39 PM
carrdoc57's Avatar
Default 1993 fleetwood passkey fault 01-43
Would like to get some info on why light stays on, car starts and runs fine, I'm helping in the sale of the car for an estate and really would like to get that light out. Thank's Mark
Old 03-22-2007, 06:36 PM
G.A.R.Y.'s Avatar
Default RE: 1993 fleetwood passkey fault 01-43
Cardoc
Which lights are you talking about?
Old 05-18-2010, 06:56 PM
Shawn26h's Avatar
Default Same problem
My 94 cadillac fleetwood brougham has the same issue. The interior lights do not shut off when all dores are closed, they stay on constantly. I took all 4 dores apart and disconnected all the harnesses and put the fuse back in and all the interior lights were still on. Anyone know the problem or what to look for? Also replaced the time delay relay and still no progress and also checked the headlight switch and that was fine as well. Any help? Thank you.
Old 05-19-2010, 09:21 AM
This should be a new thread, oh well, do you have FSM? You have a short; which can been anywhere. You will need wiring diagram as well and connector locations to isolate short. The other is to pull "A" pillar moulding, visors, map light, sail panel trim, ... looking for chaffed wire - most likely - white - in color. When you disconnected door harnesses - explain?
09-27-2017 10:07 AM
stinger
10-16-2012 05:40 PM
AIeradi
07-24-2009 11:21 AM
geargrinder
11-20-2007 12:25 AM
ame0616b
11-09-2006 10:45 PM
Quick Reply: 1993 fleetwood passkey fault 01-43
